Radial Blur
images/download/attachments/41798795/viz_icons_filterradialblur.png
Use this plug-in if you want to blur the object in different ways.
images/download/attachments/41798795/plugins_shader_radialblur_scene_examples.png
The samples above depict the same image with radial blur quality set to Low, Normal, High and Very High with Center X and Y set to -25.0 and 25.0, Inner Range and Scale set to 25.0 and 50.0, respectively.
Note: Radial blur does not clamp the object.
Note: This plug-in is located in: Built Ins -> Shader -> Filter
Radial Blur Properties
images/download/attachments/41798795/plugins_shader_radialblur_editor.png
  • Quality: Sets the quality of the blur filter. Low is more pixelated, whereas very high is smooth. Available options are Low, Normal, High and Very High.
  • Center X and Y: Sets the position of the object’s radial blur.
  • Inner Range: Sets the inner range of the blur.
  • Scale: Sets the scale of the object’s blur.
