Data Storage
images/download/attachments/41798740/viz_icons_datastorage.png
The Data Storage plug-in stores data in the current Scene and sends it to the other plug-ins on startup. This plug-in helps artists during Scene design if there is no data source available, and to hold data within, for example, the Scene (see ).
Note: This plug-in is located in: Built Ins -> Container plug-ins -> VisualDataTools
Data Storage Properties
images/download/attachments/41798740/plugins_container_datastorage_editor.png
  • Shared Mem.: Changes between Scene, Global and Distributed Shared Memory. Use Inactive memory to not forward any values via Shared Memory.
  • Key Data 1-5: Determines Shared Memory key name.
  • Data 1-5: Contains (separated) data.
  • Resend Data: Resends the actual values.
To Store and Send Data
  1. Create a chart scene, e.g. using the Line Chart plug-in and set Shared Mem. to Scene
  2. Add the Data Storage plug-in to the scene and set Shared Mem. to Scene
  3. Open the DataStorage editor and set the following parameters:
    • Shared Mem. to Scene
    • Key Data1 to Data1
    • Data1 to 10, 20, 15, 30, 25, 40, 20
      images/download/attachments/41798740/plugins_container_linechart_editor_key-data-y.png
  4. Open the Chart plug-in editor and set the Key DataY value (e.g. Data1) using the Key Data1 value you set for the DataStorage plug-in
    Note: The chart plug-ins have different property names (e.g. Data and Key Data). Also, some have X, Y or Z appended at the end, defining the axis.
    images/download/attachments/41798740/plugins_container_datastorage_example.png
  5. Open the DataStorage editor and click the Resend Data button.
To Enable Data Input from External Sources
images/download/attachments/41798740/plugins_container_controlparameter_editor-example.png
The following example builds on the previous example.
  1. Add the Control Parameter to the scene tree. The Control Object plug-in is automatically added.
  2. Open the Control Parameter editor.
  3. Enter FUNCTION*DataStorage*Data1 into the Parameter field.
  4. Set Data Type to Text. This allows you to pass a string of numbers to the Control Parameter plug-in that are stored in the shared memory. It also allows your template designer or operator to further extend/enhance the input methods through e.g. scripting.
