Star
images/download/attachments/41797584/viz_icons_star.png
Use this plug-in to create a Star with different attributes.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Star Properties
images/download/attachments/41797584/plugins_geometries_star_edit.png
  • Corners/Tips: Sets the number of corners on the inner circle of the star (equals the number of tips on the outer circle of the Star). Default: 5, Min: 3, Max: 300.
  • Star Radius: Sets the radius of the outer circle (where the tips of the star are located). Default: 50, Min: 1, Max: 200.
  • Star Inner Radius Factor: Determines the factor of the outer radius to the inner radius of the star. A value of 1.0 means that the inner radius of the star is identical to the Star Radius value. Default: 2, Min: 0.25, Max: 50.
  • Hole: Places a hole in the Star geometry. Default: 0 (Off).
  • Hole Radius: Sets the radius of the outer circle where the tips of the hole are located. Default: 25, Min: 1, Max: 200.
  • Hole Inner Radius Factor: Determines the ratio of the outer radius to the inner radius of the hole. A value of 1.0 means that the inner radius of the hole is identical to the Hole Radius. Default: 2, Min: 1, Max: 50.
To Create a Star
images/download/attachments/41797584/plugins_container_star_default_annos.png
  1. Create a new container.
  2. Add the Star plug-in to it (1 (default Star)).
  3. Open the Star editor.
  4. Modify the Star parameters, for example (2).
    • Corners: 10.
    • Star Radius: 60.
    • Star Inner Radius Factor: 6.0.
    • Hole: On.
    • Hole radius: 50.
    • Hole Inner Radius Factor: 9.0.
  5. If required, add a material and/or a texture.
