Container and Scene Properties
This section details how to add Items and Built Ins to a Container, multiple Containers and Scenes.
Most properties can be dragged to a target Container, or Containers, in the Scene Tree (1), the Properties Panel (2) or the Scene Editor (3). Each property also has a context menu where a property can also be added to a Container, multiple Containers and Scenes.
images/download/attachments/44381787/manage_elements_plugin_dragdrop_annos.png
This section containers the following procedures:
To Add Properties to an Empty Scene Tree
These properties can be added to an empty Scene Tree:
Items
Built In
  • Geometries
  • Images
  • Fontstyles
  • Geometries
  • Media Assets
  1. Drag a property to either:
    • The Scene Tree (creates a new Container)
    • The Scene Editor (creates a new Container in the Scene Tree)
      Tip: If multiple Geometry or Image items are dragged from the Item List to the Scene Tree, a Container for each selected item is created.
To Add Properties to a Container
These properties can be added to a Container:
Items
Built In
  • Geometries
  • Materials
  • Material Advanced
  • Images
  • Fontstyles
  • Geometry plug-ins
  • Container plug-ins
  • Shaders
  • Media Assets
Only one Geometry plug-in, one Shader or one Media Asset can be applied to a single Container. If a new Geometry plug-in, Shader or Media Asset is added the first one is removed from the Container.
Tip: If a Shader, Media Asset or a few Container plug-ins are dragged to an object in the Scene Editor, they are added to the Container which contains the Object. The Media Asset is added as a Texture. If a Container plug-in can be added this way, the object becomes active when the Container plug-in is moved over the object.
  1. Select a Container.
  2. Right-click a property and select Add to Container(s). Media Assets give the option to Add <Media Asset> as DVE or as Texture.
    Note: If no Container is selected the property is added to the top container in the Scene Tree.
    or
  • Drag the property to a Container
    Note: Media Assets are added as Texture to the Container.
    Material items only:
  1. Right-click a Container
  2. Click on Add Material...
To Multi Drop Properties as Sub Containers
These properties can be multi dropped and create Sub Containers:
Items
Built In
  • Geometries
  • Images
  • Fontstyles
  • Geometry plug-ins
  • Media Assets
  1. Drag a selected property to the Scene Tree (aligned with a Container).
  2. Hold the left-click and right-click to add the property to a new Sub-Container of the highlighted Container.
  3. Keep the left-click and repeat as required.
    Tip: Also works if multiple Geometries are selected.
    Note: When the last property to be added has been dropped, release the right-click while the cursor is still aligned the target Container. If the right-click is released when over or aligned with another Container, another (not required) Container or Sub-Container, and Property is added.
    Note: A Media Asset is added as a Texture.
    images/download/attachments/44381787/import_archive_add_built_in_sub_contianer_anno.png
To Multi Drop Properties on Containers
These properties can be multi dropped on Containers:
Items
Built In
  • Materials
  • Material Advanced
  • Image
  • Fontstyles
  • Geometries
  • Shaders
  • Media Assets
  1. Drag a property over a Container.
    Tip: These properties can be dragged to the Scene Tree and aligned with a Container to add them: Materials, Materials Advanced, Container plug-ins and Shaders.
  2. Hold the left-click, and right-click to add the property to the highlighted Container.
    Note: When the last property to be added has been dropped, release the right-click while the cursor is still over the target Container. If the right-click is released when over or aligned with another Container, another (not required) Container or Sub-Container, and Property is added.
To Add Multiple Properties to Containers
These properties can be Multi Added to a Container:
Items
Built In
  • Geometries
  • Images
None
  1. Multi select the required properties.
  2. Drag the selected properties to the Scene Tree or a Container:
    • In the Scene Tree (1(aligned with a Container)): All selected properties are placed in the Scene Tree as sub-containers of the highlighted Container, or
    • Over a Container (2). The first selected property is added to the highlighted Container and the other selected properties create new Containers, at the same level
      images/download/attachments/44381787/manage_elements_add_multi_geometries_anno.png
To Add Properties to Multiple Containers
These properties can be added to Multiple Containers:
Items
Built In
  • Geometries
  • Materials
  • Material Advanced
  • Image
  • Fontstyles
  • Geometries
  • Shaders
  1. Multi select the required Containers.
  2. Add a property:
    • Right-click a property and select Add to Container(s),
      images/download/attachments/44381787/manage_elements_add_context_container.png
      or
    • Drag a property to one of the multi selected Containers.
To Add a Scene Plug-in to a Scene
  1. Open the plug-in tab in Video Clip Playback Considerations:
    • Click on Scene Settings > plug-in, or
    • Click on the Scene plug-in icon (1)
      images/download/attachments/44381787/manage_elements_sp_icon_anno.png
  2. Drag a Scene plug-in icon to the Scene drop area.
    or
  1. Right-click the Scene plug-in icon to open the plug-in Context Menu.
  2. Click on Add to Scene...
    If a Scene plug-in has been applied to a Scene, the Scene plug-in icon shows orange images/download/attachments/44381787/manage_elements_sp_icon_2.png .
