PixelFX Plug-ins
The PixelFX plug-ins affect pixels and geometry, and produce various special effects. They do three main things:
  • Color correction
  • Lens flares
  • Other pixel-based effects, such as noise, gradients, various distortion effects, transitions, and similar effects.
    The icon for each of the plug-ins have mini icons that show certain properties of the particular plug-in.
images/download/attachments/44376611/ico_pxbcubic.png
  • At the bottom left, there is a performance bar, with three blocks (like a cellphone battery indicator). One block means the plug-in does not have a drastic performance effect, and three means the plug-in is taxing and should therefore be used with caution.
  • At the bottom right the orange stack shows if the plug-in is stackable, meaning it can be used in conjunction with color correction plug-ins.
  • Some plug-in icons themselves are divided in half with one side showing the visual effect with the plug-in and the other without it.
    Some of the PixelFX plug-ins work only when applied to a Container that also has a Texture. The rest however, function on the Renderer’s pixel buffer. For example, you may apply color correction to the root Container in a Scene, therefore perform a color correction to the whole scene. Another example is pxNoise- apply it to the root level container of a scene or a whole tree branch to add a kind of film-grain effect.
One of the parameters that feature in a number of the PixelFX plug-ins is Seed. This defines the pseudo-random rule for changed parameters. Once a value is chosen, although the original state is random, the effect actually looks the same on other computers as well.
images/download/attachments/44376611/pc_pxcw.png
