Text FX Emoticons
images/download/attachments/41798398/viz_icons_tfxemoticons.png
The Text FX Emoticons allows you to create an emoticon container, add it to the Emoticons plug-in and replace characters (tokens) in a text string with an assigned container.
IMPORTANT! This plug-in is located in: Built Ins -> Container plug-ins -> TextFX
Text FX Emoticons Properties
images/download/attachments/41798398/plugins_container_textfx_emoticons_editor.png
  • Autoscale: Scales the emoticon containers so their height above the baseline (0) is identical to the height of character A.
  • UTF-8 Encoding: Enables UTF-8 encoding for the text effect.
  • Token 1 - n: Sets the placeholder for an emoticon.
  • Container 1 - n: References the container holding the emoticon. The container should be similar to the layout of a glyph.
  • Precache 1-n:- Enables Viz Artist/Engine to cache the objects.
