Stage Shortcuts
General
Function
Key and/or Mouse
Show Obj. Editor
Ctrl+1
Dopesheet View
Ctrl+2
Shift+Page Down
Spline View
Ctrl+3
Shift+Page Up
Dope/Spline View
Ctrl+4
Stage Tree
Function
Key and/or Mouse
Jump to Top Container
Home
Jump to Last Container
End
Move a page down in the tree
Page Down
Move a page up in the tree
Page Up
Scroll up the tree
Cursor up
Scroll down the tree
Cursor down
Jump to an item (Director, Actor, or Channel), in the tree
Press the first letter of the item name
Open or close the selected tree
Return
Numeric keyboard Return
Stage Views
Function
Key and/or Mouse
Start/Continue Animation Forward
Space
Start Animation Backwards
Shift+Enter
Set Time-line Marker/Value to Start
Ctrl+Home
Set Time-line Marker/Value to End (not when infinity is selected)
Ctrl+End
Set View to 0
Home
Set View to End director
End
Move the Time-line Marker one field
Ctrl and the left or right arrow key
Move the Time-line Marker more than one field at a time
Left or right arrow key. This, for example, in 1080i50 format, moves the time-line marker five fields, left or right, and in 1080i60 the movement is six fields, left or right.
Alt and the left or right arrow key. This, for example, in 1080i50 format, moves the time-line marker 50 fields, left or right, and in 1080i60 the movement is 60 fields, left or right
Delete Selected Key Frame(s)
Delete
Pan View
Middle mouse click and drag
Zoom Time Axis In or Out
Mouse wheel
Zoom Time Axis to Selected Channel
Shift+Z
Shift+Y
Zoom Time Axis to whole Animation
Shift+X
Zoom Spline/Dopesheet View In
Mouse wheel
Z/Y
Ctrl + Plus sign on the numeric keypad
Zoom Spline/Dopesheet View Out
Mouse wheel
X
Ctrl + Minus sign on the numeric keypad
Zoom Spline View to whole Spline
Shift+A
Zoom Time Axis and Spline View to view all Key Frames of selected Channel
Shift+Q
Zoom Time and Value Axis to View All Key Frames
Shift+W
Zoom Time Axis In/Out
Z+Middle mouse click and drag
Zoom Value Axis in Spline Editor In/Out
A+Middle mouse click and drag
Copy Selected Key Frame
C+Left mouse click and drag
Bring View to Time-line Marker
M
Reverse the Order of Selected Key Frames
Ctrl+R
Snap to Grid on/off
Ctrl+G
Set Time Axis to Seconds
Ctrl+8
Set Time Axis to Frames
Ctrl+9
Set Time Axis to Fields
Ctrl+0
Move Time-line Marker to nearest Key Frame
J
Scale a Portion of Selected Director
T+Left mouse click on Director Bar
This shows a region where Key Frames can be scaled.
Rubber band Selection
S+Left mouse click and drag
Zoom in onto specific region
Z+Left mouse click and drag
Insert a new Stop Point
S+Left mouse click on Director Bar
View Spline 1 (Rotation Channel Only)
Ctrl+Z
View Spline 2 (Rotation Channel Only)
Ctrl+X
View Spline 3 (Rotation Channel Only)
Ctrl+C
Jump to next Key Frame
Tab (a Key frame must be highlighted first)
Jump to previous Key Frame
Shift+Tab
Escape from moving a Key Frame
Esc
