![](assets/images/logos/VizWorldLogo.png)
Viz World Classic User Guide
Adding Satellite Imagery
You can add geo-referenced satellite imagery to your base map. Other features like street data appear on top of it.
To Add Satellite Imagery to the Base Map
From the View menu select Options.....
Select Locations and click Installed Imagery....
Click the + button and open the CMR files.
Click the Fit images to selected map button and close the window.
From the Styles menu select Styles Editor....
Select the Topography tab.
Select your style sheet and set it to Natural Earth. All satellite images appear as part of your map; however, they only appear if you use style sheets based on Natural Earth.
Optional: From the Contents tab select the Streets tab and load the street data for your region to see how streets are overlaid.
