 Viz World Classic User Guide
Defining the Text Layout
The options on the Layout panel (depicted above) allow you to move, scale, or rotate a text item, adjust the kerning, or align or space evenly multiple text items.
To Move a Text Item
-     Select the Move Text tool  . .
-     Position the mouse pointer within the text item.
-     Drag the text item to the new position:
 This allows you to move a text item even if the position handle is out of view.
To Scale Text
-     Drag one of the handles on the border of the text item:
-     Drag while holding down CTRL to scale the text proportionally.
To Rotate Text
-     Point to the rotation handle, the yellow circle to the right of the center of the text item.
-     Drag the handle to rotate the text item about its center:
To Adjust the Letter Spacing
-     Select the Text Kerning tool. The Viewer indicates the position of each character by a marker on the baseline:
-     Drag a marker to the left or right to adjust the spacing between the corresponding characters.
-     When you have finished kerning the text, click the Text Kerning tool again. Tip: You can reset the default kerning of the text by clicking the Reset button.
To Align Several Text Items
-     Select at least two text items in the list, using SHIFT to select multiple items.
-     Choose the appropriate alignment option from the Align context menu (see above).
To Space Several Text Items Evenly
-     Select at least three text items in the list, using SHIFT to select multiple items.
-     Choose the appropriate alignment option from the Space Evenly context menu.
