Viz World Classic User Guide
Changing the Position, Size, or Angle of the Light
When you add a light the Light tool is selected in the Lighting panel to allow you to move, scale, or rotate the light. The extent of the light is shown as a circle:
To Move the Light
Position the mouse pointer anywhere within the circle and drag the light to the required position.
To Change the Size of the Beam
Drag the outline of the surrounding circle.
To Stretch the Beam in One Direction
Drag the light by one of the four handles on the surrounding circle:
To Change the Angle of the Light
Drag the handle extending from the center of the circle:
To Specify the Parameters of a Light Numerically
Edit the X, Y, Width, Height, and Angle values in the Lighting panel.
