![](assets/images/logos/VizWorldLogo.png)
Viz World Classic User Guide
Creating GIF Images
Viz World Classic cannot create or render GIF format images by default. It works with some commercially available third-party GIF creation applications to allow creation of GIF images.
Supported applications are as follows:
Platform Application
PC FCoder 2GIF
Mac Lemke Software Graphic Converter
To Set up Viz World Classic for GIF Image Creation
Purchase and install one of the supported GIF creation applications. If you are running Viz World Classic on Windows, then you must specify the location of the 2GIF application.
On the View menu, click Options....
In the File formats section click Gif.
Click the Browse... button and select the path of the 2GIF application:
The GIF file format and associated options are then available in image save, export, and render windows.
