Program Examples
To explain the described terms and definitions, this section shows some source code examples and explains the important steps and commands.
Most of the examples detailed here are written in an easy and understandable form for programing beginners. Some are basic, while others are more advanced and specific for their use case. More efficient code structures and improvements are possible.
Initializing Scripts
This example declares and defines two variables with a value. In the main procedure OnInit() those two variables and their addition are output to the console using Println.
Callback procedures like OnInit() are used to initialize scripts.
'Declaration of the variables
dim a as Integer
a =
10000
dim b as Integer
b =
5000
'Start of the main procedure sub OnInit()
'Executing the commands
println
"\n"
println
"The variable a has the following value: "
& a
println
"\n"
println
"The variable b has the following value: "
& b
println
"\n"
println
"The sum of the variables is: "
& a + b
'End of the main procedure
end sub
Result output to the Viz Engine console:
Register Parameters
This script example creates a custom editor for filling in index and alpha values. The index value decides which container does not receive the alpha value, whereas the alpha value is set for all other containers.
sub OnInitParameters()
RegisterParameterInt(
"index"
"Index"
1
1
7
RegisterParameterDouble(
"alpha"
"Alpha"
50.0
0.0
100.0
RegisterPushButton(
"action"
"Action"
1
end sub
sub OnExecAction(buttonId as Integer)
dim c as Container
dim i, index as Integer
dim a as Double
index = GetParameterInt(
"index"
a = GetParameterDouble(
"alpha"
i =
1
c = ChildContainer
do
while
c <>
null
if
i = index then
c.alpha.value =
100.0
else
c.alpha.value = a
end
if
i = i +
1
c = c.NextContainer
loop
end sub
Mouse Events I (Set)
This script example shows how to use a ‘mouse event’” to set an object’s alpha value with OnEnter and OnLeave.
sub OnEnter()
alpha.value =
100.0
end sub
sub OnLeave()
alpha.value =
50.0
end sub
Mouse Events II (Start, Stop and Reverse)
This script, when added to a container, allows an animation to be started with the click of a mouse button over an object (for example, rectangle). Press again and it stops. Press again and it continues from the point it stopped.
dim my_dir = stage.FindDirector(
"Default"
sub OnLButtonDown()
if
my_dir.IsAnimationRunning() then
my_dir.StopAnimation()
else
my_dir.ContinueAnimation()
end
if
end sub
With the script detailed below, start an animation and let it run until a stop point. Click again and it runs in reverse:
"Defult"
sub OnLButtonDown()
menu.ContinueAnimation()
if
my_dir.reverse ==
true
then
my_dir.reverse =
false
else
my_dir.reverse =
true
end
if
end sub
Mouse Events III (Grow and Shrink)
With this script added to a Container an object grows when the mouse is hovering over the object and conversely. In this case, the center of the object is set to the lower right corner to let it grow out from that center.
dim growing as Boolean =
false
"min"
"MinScale"
1.0
0.0
10.0
"max"
"MaxScale"
1.5
0.0
10.0
"fac"
"GrowFactor"
1.1
1.0
10.0
end sub
sub OnEnter()
growing =
true
end sub
sub OnLeave()
growing =
false
end sub
sub OnExecPerField()
dim min = GetParameterDouble(
"min"
dim max = GetParameterDouble(
"max"
dim fac = GetParameterDouble(
"fac"
if
growing then
scaling.xyz *= fac
if
scaling.x > max then scaling.xyz = max
else
scaling.xyz /= fac
if
scaling.x < min then scaling.xyz = min
end
if
end sub
Simple Gesture Recognition
This example script can be used to detect a drawn square on the screen:
dim gRecognizer as gesturerecognizer
sub OnInit()
gRecognizer.handlepatterns =
true
gRecognizer.addhandler(scriptplugininstance)
end sub
sub OnGesture(gesture As Gesture)
if
gesture.patternid == PATTERN_SQUARE then
println(
"This is a square"
end
if
end sub
sub OnTouchTrace(trace as Trace, touch as Touch)
gRecognizer.addtrace(trace)
end sub
Note: Some gesture patterns need to be checked for their alignment as well, for example up, down, left, and so on. For this you can activate the CheckPatternOrientation property in the gesture recognizer object.
Calculate the Days of a Week and Month
This script example calculates the day of the week and the number of days of the month:
DIM smap AS Array[String]
smap.size =
7
smap[
0
"Sun"
smap[
1
"Mon"
smap[
2
"Tue"
smap[
3
"Wed"
smap[
4
"Thu"
smap[
5
"Fri"
smap[
6
"Sat"
function CalcDayOfWeek(iYear AS Integer, iMonth AS Integer, iDay AS Integer) AS String
DIM dt AS DateTime
dt.year = iYear
dt.month = iMonth
dt.dayofmonth = iDay
dt.normalize()
CalcDayOfWeek = smap[dt.dayofweek]
end function
function CalcNumOfDaysOfMonth(iYear AS Integer, iMonth AS Integer) AS Integer
DIM dt AS DateTime
dt.year = iYear
dt.month = iMonth+
1
dt.dayofmonth =
0
dt.normalize()
CalcNumOfDaysOfMonth = dt.dayofmonth
end function
sub OnInit()
DIM dt AS DateTime
dt.year =
2019
dt.month =
2
dt.dayofmonth =
23
println(
"Date: "
& CalcDayOfWeek(dt.year, dt.month, dt.dayofmonth) &
& dt.year &
& dt.month &
& dt.dayofmonth)
println(
"Days: "
& CalcNumOfDaysOfMonth(dt.year, dt.month))
end sub
Update a Scene Using a Text File
This script example updates a Scene from a text file.
dim timer,limit as integer
timer =
0
RegisterInfoText(
"Text File Grabber 1.0"
& chr(
10
) & chr(
10
"Grabs text file and puts optional prefix/suffix around the contents of the text file."
& chr(
10
"Filename supports paths with drive letters and UNC paths."
& chr(
10
) & chr(
10
"Text in \"Default Text\" box is used if file specified in File box cannot be opend or accessed."
& chr(
10
) & chr(
10
"Listens to scene map variable \"text_update\" -- text files are re-read when this variable changes."
RegisterFileSelector(
"file"
"File"
"c:\test"
"1.txt"
RegisterParameterString(
"default"
"Default text"
40
50
"prefix"
"Prefix (optional)"
40
50
RegisterParameterBool(
"prefixIfNull"
"Include prefix if file not found"
,FALSE)
"suffix"
"Suffix (optional)"
40
50
"suffixIfNull"
"Include suffix if file not found"
,FALSE)
"updateFields"
"Auto-Update interval (fields)"
300
60
999999999999
"debug"
"Debug output to console"
,FALSE)
end sub
sub OnParameterChanged(parameterName As String)
're-populate text when a parameter changes
if
parameterName <>
"updateFields"
then UpdateText
if
parameterName =
"updateFields"
then
limit = GetParameterInt(
"updateFields"
end
if
end sub
timer = timer +
1
if
timer >= limit then
if
GetParameterBool(
"debug"
) then println
"Timer limit reached"
UpdateText
timer =
0
end
if
end sub
sub OnInit()
Scene.Map.RegisterChangedCallback(
"text_update"
"updateFields"
UpdateText
end sub
sub OnSharedMemoryVariableChanged(map As SharedMemory, mapKey As String)
if
mapKey =
"text_update"
then
UpdateText
end
if
end sub
sub UpdateText()
geometry.text = GetTextFile()
end sub
function GetTextFile() as string
dim content, path as string
path = GetParameterString(
"file"
if
GetParameterBool(
"debug"
) then println
"File path: "
& path
if
System.LoadTextFile( path, content ) then
if
GetParameterBool(
"debug"
) then println
"Successfully loaded file"
content.trim
if
len(GetParameterString(
"prefix"
0
then content = GetParameterString(
"prefix"
& content
if
"suffix"
0
then content = content &
& GetParameterString(
"suffix"
else
if
GetParameterBool(
"debug"
) then println
"Could not load file; using default text"
"default"
if
GetParameterBool(
"prefixIfNull"
) then content = GetParameterString(
"prefix"
& content
if
GetParameterBool(
"suffixIfNull"
) then content = content &
"suffix"
end
if
GetTextFile = content
if
GetParameterBool(
"debug"
) then println
"Returning '"
& GetTextFile &
end function
