Anisotropic Light
images/download/attachments/27789732/viz_icons_anisotropiclight.png
This shader uses a lookup texture to compute the distribution of the specular component. All the shader properties are defined by the material of the container. Only Light number 1 is used and the light is always treated as a local light source.
In the figure below the left image is with anisotropic light and the right image is with a regular material.
images/download/attachments/27789732/plugins_shader_anisotropiclight_scene_examples.png
Note: This plug-in is located in: Built Ins -> Shader -> Material
Anisotropic Light Properties
images/download/attachments/27789732/plugins_shader_anisotropiclight_editor.png
This plug-in does not have any properties or parameters.
