Lens Flare Geometries
images/download/attachments/27789089/plugins_container_pxlensitems.png
The following lens flare plug-ins are simply different shapes for the composition of final lens flare effects. Each has its own parameters to define its appearance.
  • pxLensGlowBall
  • pxLensGlowSpikes
  • pxLensPolyitem
  • pxLensRandomPoly
  • pxLensSpark
  • pxLensStripes
Each plug-in can in its own right take on very different appearance depending on how the parameters are adjusted. The best advice for working with these plug-ins is to simply play around with the parameter configurations. The following example shows varying manifestations of the pxLensRandomPoly.
images/download/attachments/27789089/plugins_container_pxscreen2.png
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> PixelFX
