Control Bars
images/download/attachments/27789238/viz_icons_controlbars.png
The Control Bars plug-in allows binding of tab field values to the Bar Value fields in the Bar values presenter plug-in. Each bar value property in the Bar Values editor is presented as a separate tab field in Viz Trio.
Control Bars Properties
images/download/attachments/27789238/plugins_container_controlbars_editor_r.png
  • First Bar Field ID: Sets the tab-field ID for the first Bar value.
  • Last Bar Field ID: Sets the tab-field ID for the Last Bar value
  • Expose Bars Max/Total Value: If enabled the Bars Max/Total value will be exposed as a separate tab field.
