Stereoscopic Output Using Shutter Glasses
It is very easy to set up a working 3D environment for a designer to start creating stereoscopic scenes. The demands on the hardware are moderate.
Hardware Requirements
  • Any workstation
  • Any NVIDIA Quadro graphics card with a 3-pin DIN connector
  • NVIDIA 3D vision or equivalent
  • Monitor with a refresh rate >= 100Hz
Software Requirements
  • Viz Artist/Engine 3.3 or later
  • The display must be set to a refresh rate >= 100Hz
To Set Up a 3D Working Environment
  1. In the Windows video board 3D settings, Set Stereo - Enable to On
  2. Select the appropriate Stereo - Display mode for each stereo device.
    Note: For NVIDIA’s 3D Vision this is ‘On-board DIN connector’.
    images/download/attachments/37570466/cameras_stereo5.png
  3. In Camera settings (see section Configuring Viz of the Viz Engine Administrator’s Guide) set Stereo Mode to Quad Buffered.
    images/download/attachments/37570466/cameras_stereo6.png
    Also it is possible to use an autostereoscopic monitor that supports sub-fields or side-fields, such as Miracube’s c190 series. The drawback with these displays is that you need to go on-air to get a full-screen image, which is halved in resolution.
