Chroma Keyer
images/download/attachments/27789686/viz_icons_chroma_key.png
This Shader clear regions in a video defined by a color. The color-space of this Shader is YUV, which is defined as following:
images/download/attachments/27789686/import_archive_keying3.png
The luminance (Y) component determines the brightness of the color, while the U and V components determine the color itself (the chroma). Luminance (Y) ranges from 0.0 (dark) to 1.0 (bright). U and V ranges from -0.5 to 0.5.
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Chroma Keyer Properties
images/download/attachments/27789686/plugins_shader_chromakeyer_editor_1.png
  • Video: Sets the input video channel for keying. Be sure that for the set video channel the “Keying Mode” has been set to M-Zone (see Keying Mode).
  • Blend: Sets the alpha for the key signal
  • Fit: Select Screen or Object
  • Invert: Flips the key signal.
  • Sampling Filter
    • Nearest: Color information is taken from one pixel.
    • 1D-Filter: Color information is taken after applying a 1D-linear filter.
    • 2D-Filter: Color information is taken after applying a 2D-linear filter.
  • Luminance: Sets the luminance.
    Basic parameters for first method:
images/download/attachments/27789686/plugins_shader_chromakeyer_editor_method1.png
  • HueAngle: Selects the color to key in YUV space.
  • OpeningAngle: Tolerance for the color in YUV space.
  • KeyGain: Gradient for borders to neighboring colors (1=soft, 10=sharp).
  • SatMin: Lower saturation limit for keyed colors.
  • SatMinGrad: Gradient for lower saturation limit (0=sharp, 1=soft).
  • SatMax: Upper saturation limit for keyed colors.
  • SatMaxGrad: Gradient for upper saturation limit (0=sharp, 1=soft).
    Basic parameters for second method:
images/download/attachments/27789686/plugins_shader_chromakeyer_editor_method2.png
  • U-Color: U-value for color keying.
  • V-Color: V-value for color keying.
  • UV-Diameter: All colors between the reference UV and this diameter will be removed.
  • UVGradient: Gradient for fade out at diameter border (0=sharp, 1=soft).
    Removing keying from Highlights and Shadows:
images/download/attachments/27789686/plugins_shader_chromakeyer_editor_2.png
  • LumMin: Lower luminance limit for keyed colors.
  • LumMinGrad: Gradient for lower luminance limit (0=sharp, 1=soft).
  • LumMax: Upper luminance limit for keyed colors.
  • LumMaxGrad: Gradient for upper luminance limit (0=sharp, 1=soft).
    Sampling reference point:
images/download/attachments/27789686/plugins_shader_chromakeyer_editor_3.png
  • UVRangeCheck: This option can be used to get an information of the sampled color
  • URangeMin: Defines the minimum UColor that should be accepted
  • URangeMax: Defines the minimum UColor that should be accepted
  • VRangeMin: Defines the minimum UColor that should be accepted
  • VRangeMax: Defines the minimum UColor that should be accepted
  • SampleTrustiness: Percentage of samples in the limited UV-Color space
    images/download/attachments/27789686/plugins_shader_chromakeyer_editor_4.png
  • Pos. X: X-coordinate for sampling.
  • Pos. Y: Y-coordinate for sampling.
    Note: The origin of the coordinate system is in the upper left corner.
  • Width: Sets number of pixels in x-direction.
  • Height: Sets number of pixels in y-direction.
  • Sample at Pos: If enabled Pos. X and Pos. Y will be replaced by XY-coordinates of the object center. If disabled the XY-coordinates will be set by values in the interface.
  • Get Sample: Sample another time the reference point.
To use the Chroma Keyer, a license must be present. ENG_PLUG_CHROMAFX
