Control Hide in Range
images/download/attachments/27789238/viz_icons_controlhideinrange.png
The Control Hide in Range plug-in hides or shows a container if the input value given by the user is within or outside a specified value range. The input value must be from a font container that holds a numeric value, typically with a Control Num plug-in.
Control Hide in Range Properties
images/download/attachments/27789238/plugins_container_controlhideinrange_editor_r.png
  • Input Value: Shows the current input value
  • Lower Range Bound: Sets the upper bound for the range
  • Upper Range Bound: Sets the lower bound for the range
  • Visibility in Range: Sets if the container should be visible or hidden when the input value is within the range.
