Cog Wheel
images/download/attachments/27788946/viz_icons_cogwheel.png
Use this plug-in to create a cog wheel. It has a range of properties to adjust the look of the cog wheel.
To avoid decreasing the system performance, set the tessellation to a lower value since it does not make much difference in quality.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Cog Wheel Properties
images/download/attachments/27788946/plugins_geometries_bipcogwheeledit.png
  • Use LOD enables/disables dynamic level of detail.
  • Tesselation sets the level of detail.
  • Corners sets the number of corners the cogwheel is to be constructed of. The cog wheel gets one tooth for each corner, so the number of teeth changes correspondingly.
  • Height sets the height or width of the cog wheel.
  • Tooth height sets the height of the cog wheel teeth.
  • Diameter sets the diameter of the cog wheel.
  • Hole creates and sets the size of a hole in the cog wheel.
  • Bevel sets the degree of bevel at the cog wheel.
  • Inner Bevel enables or disables bevel in the cog wheel hole.
  • Show Top enables or disables visualization of the top.
  • Show Bottom enables or disables visualization of bottom.
  • Center allows you to select where the geometrical centre should be placed on the cog wheel, either Center, Bottom or Top.
To Create a Cogwheel
images/download/attachments/27788946/plugins_geometries_bipcogwheel_example.png
  1. Add the Cog Wheel plug-in to a container.
  2. Add a material to the same container.
  3. Set Hole parameter to 50.0.
  4. Set the transformation parameters for the container to:
    • Set rotation X: 90.0, Y:45.0 and Z: -45.0.
