CFX Plus Plus
images/download/attachments/27789210/viz_icons_cfxplusplus-icon.png
The Container FX Plus Plus plug-in allows you to set a number of effects on a container’s set.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> ContainerFx
CFX Plus Plus Properties
images/download/attachments/27789210/plugins_container_cfx_plusplus_editor.png
  • Position Wrap
    • Extrapolate: Above 100% or below 0% of Path Position will continue the direction of the spline.
    • Clamp: Will stop the string on the spline endpoints.
    • Repeat: Will cause the string to move to the other spline endpoint as soon as it moves over the endpoint.
    • ContainerFx: Will position containers by the relative spline of each container using the ContainerFx parameters.
  • Scheme Type: Defines how the container-set will look at 0% and 100% progress.
    • In -> In: at 0% first container will be at the beginning of the spline, at 100% last container will be at the end of the spline.
    • In -> Out: at 0% first container will be at the beginning of the spline, at 100% first container will be at the end of the spline.
    • Out -> In: at 0% last container will be at the beginning of the spline, at 100% first container will be at the end of the spline.
    • Out -> Out: at 0% last container will be at the beginning of the spline, at 100% last container will be at the end of the spline.
  • Progress (%): Animates the progress of the effect(s).
