Text FX Color Per Vertex
images/download/attachments/27789481/viz_icons_tfxcolorpervertex.png
Adds a color per vertex effect to the text.
Note: Works only if the text is set to texture (does not work with geometry text).
Text FX Color Per Vertex Properties
images/download/attachments/27789481/plugins_container_textfx_colorpervertex_editor_r.png
  • Color Bbox: Defines the reference bounding box, global for the entire text, or local for each character.
  • Color Direction: Defines the color gradient shape. Available options are; top left to bottom left, top right to bottom right, top left to top right, bottom left to bottom right, top right to bottom left and 4 corners.
  • Color Level: Sets the level of the color (0.1 to 1.9). Default is 1.0.
  • Top and Bottom Left and Right: Sets the color and alpha value for each edge.
  • Color use Alpha: Enables alpha.
