Noggi
images/download/attachments/27788946/viz_icons_noggi.png
Use this plug-in to create geometry objects of beveled rectangles with some attributes.
Note: This plug-in is located in: Built Ins -> Geom plug-ins -> Default
Noggi Properties
images/download/attachments/27788946/plugins_container_noggi_editor.png
  • Width: Changes the width in X-direction.
  • Height: Changes the height in Y-direction.
  • Bevel (top/right, top/left, bottom/left and bottom/right): Changes the bevel on each corner.
  • Stretch: The result is an object like a parallelogram. Stretch is in percent (= tan(alpha)). If Geometry Type is Outline.
  • Horizontal Alignment: Changes the object alignment to left, center or right. This change will affect the y-rotation.
  • Vertical Alignment: Changes the object alignment to bottom, middle or top. This change will affect the x-rotation.
  • Geometry Type: Renders the object as area- or with outline look.
  • Inner Outline: Changes the vertex sequence in outline mode. Inner Outline is important for face orientation when extruding the geometry.
  • Outline Width: Changes the thickness of the rendered outline.
  • Edge Points: Change the number of triangles to render a beveled corner. Increasing the number increases the bevel resolution.
  • Crop: Enables/disables cropping of the object. Cropping and vertex texture are only available if Geometry Type is Area.
    • Crop Face (Left, Right, Bottom and Top): Crops the object on each given side.
To Create a Noggi
images/download/attachments/27788946/plugins_container_noggi_example.png
  1. Create a new group and add the Noggi plug-in to it.
  2. Add a material and/or a texture to the group.
  3. Open the transformation editor and set Position X to -150.0.
  4. Open the Noggi editor and set the following parameters:
    • Set Width and Height to 600.0 and 100.0.
    • Set Bevel top/right and bottom/left to 0.0.
    • Set Bevel top/left and bottom/right to 20.0.
