Text FX Scale
images/download/attachments/27789481/viz_icons_tfxscale.png
The Text FX Scale plug-in allows you to create a scaling animation of the characters.
Text FX Scale Properties
images/download/attachments/27789481/plugins_container_textfx_scale_editor.png
  • Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
  • Anchor Vertical: Sets the anchor point for the characters on the vertical plane.
  • Use Axis: Defines on which axis or axes the characters scale.
  • Lock Axis: With this option enables the Begin- and End scaling are the same for all the axes. If you disable the parameter, Begin and End must be set for all the axes individually.
  • Begin: Sets the initial size of the characters.
  • End: Sets the ending size of the characters.
