Create Script-based plug-ins
Scene plug-ins and Container plug-ins can be created, saved and used again in other Scenes or Containers. To do this create a plug-in of the created script.
Created Script-based plug-ins are saved as ‘.vsl’ files at <viz data folder>\Scriptplug-ins, and are available in these folders:
  • Container plug-ins -> Script plug-ins
  • Scene plug-ins -> Script plug-ins
    images/download/attachments/27789987/viz_icons_default.png
    Script-based plug-ins can be used the same as Scene or Container plug-ins, and allow the additional following operations:
  • Can be deleted: Drag the script to the trash can.
  • The source code of a script-based plug-in can be copied into a script editor. Drag the plug-in from Script plug-ins folder to the Script Editor.
To Create a Script-based plug-in
images/download/attachments/27789987/gettingstarted-scripting_create_script_plugin.png
  1. Create a script (see To Create a Container Script plug-in).
  2. Click images/download/attachments/27789987/gettingstarted-scripting_compile_icon.png .
    Note: If the script is bad a Script plug-in can not be created. Correct any bad script first.
  3. Go to Built Ins -> Container plug-ins -> Scriptplug-ins.
  4. Drag and drop the Script icon to the Scriptplug-ins folder.
    images/download/attachments/27789987/gettingstarted-scripting_save_script_plugin_anno.png
  5. Enter a name for the Script plug-in.
  6. Click OK.
To Edit a Script-based plug-in
  1. Add a Container to the Scene Tree.
  2. Add a Script plug-in.
  3. Open the Script Editor(Scene Settings -> Script).
  4. Drag and drop the required script plug-in from the Scriptplug-ins folder to the Script Editor.
  5. Click Replace.
    images/download/attachments/27789987/gettingstarted-scripting_save_replace.png
  6. Edit the script as required.
  7. Click the Compile & Run to save.
