CFX Scale
images/download/attachments/27789210/viz_icons_cfxscale-icon.png
The CFX Scale plug-in allows you to create a scaling animation of the containers.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> ContainerFx
CFX Scale Properties
images/download/attachments/27789210/plugins_container_cfx_scale_editor.png
  • See: Common Container FX Properties
  • Anchor Horizontal: Sets the anchor point for the containers on the horizontal plane.
  • Anchor Vertical: Sets the anchor point for the containers on the vertical plane.
  • Use Axis: Defines on which axis or axes the containers scale.
  • Lock Axis: With this option enabled the Begin- and End scaling are the same for all the axes. If you disable the option, Begin and End must be set for all axes individually.
  • Begin: Sets the initial size of the containers.
  • End: Sets the ending size of the containers.
