Pie Slice
images/download/attachments/27789432/viz_icons_pieslice.png
Use the Pie Slice plug-in with the Pie Values plug-in to create and animate a pie chart of up to 20 slices.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> Presenter
Pie Slice Properties
images/download/attachments/27789432/plugins_container_pieslice_editor.png
  • Obj Min / Max: Maps the input values to the values on the cylinder object. Adjust these together with Bar Max/Min on the Pie Values plug-in to get the required effect between input values and visual effect.
  • Offset: Offsets the slice from the center of the pie chart.
  • Text Offset: Offsets the text label from the center of the pie chart.
  • Control Text Values: Sets the type of text. Available options are No, Integer, Float and Formatted.
  • Initialize: Initializes the value of the pie slice.
