Manipulate Container Properties
Container properties are items and plug-ins which have been applied to a Container. There are a few operations that apply to all Container properties.
To Replace a Property Applied to a Container
  • Drag the new item or plug-in to the Container.
To Remove a Property from a Container
  • Drag the property from the Container to the trash can, or
  • Drag the property from the Container Editor to the trash can, or
  • Right-click the property on the Container in the Scene Tree, and select Delete <Name of the Property>.
    Note: Every Container must contain transformation properties, so the transformation property cannot be removed.
To Save Properties in the Database
If a scene specific property has been created, and it is likely that the property should be reused in another scene, it is possible to save the property in the database.
  • Drag the property from the Container to the required folder/project in the Server Panel.
To Enable/Disable Properties on a Container
images/download/attachments/27788217/tree_knowledge_function_on_off.png
Note: item properties are automatically enabled when added to a Container.
This is a practical tool when multiple items are applied to a Container.
  • Click the switch next to the icon which represents the item in the Container Editor.
