HDR (High Dynamic Range) Panel
Enables High Dynamic Range Rendering/Imaging for the selected container. This improves the contrast of the generated scene in a much more realistic way.
HDR Properties
images/download/attachments/27788296/import_archive_hrdpropertiespane.png
  • High Dynamic Range (Active/Inactive): Enables HDR lighting instead of the default OpenGL lighting on Containers tagged for HDR lighting. To tag Containers for HDR lighting the HDR plug-in must be placed in a Container to enable HDR lighting on the respective container and its sub-tree.
  • Diffuse Map: This is a HDR Cube map (must be a vertical cross and should have been imported from an EXR file). It defines the diffuse light map.
  • Reflection Map: Same as Diffuse map but for the reflection part of the lighting.
  • Rotation: Rotate the environment map with the set parameters.
    Note: Diffuse map and reflection map together form the ‘environment map’.
  • Exposition: Controls the brightness of the maps (similar to the exposure time of an ordinary camera).
  • Background (Active/Inactive): Draws the Reflection map as background.
