Text Auto Scale
images/download/attachments/27789571/viz_icons_textautoscale.png
Text Auto Scale automatically scales text within a Text Box area as defined in the Text Editor.
images/download/attachments/27789571/plugins_container_textautoscale_properties.png
  • Enabled: The plug-in is enabled by default when added to a container. Click the button to disable.
  • Default x-scale: Set the default scale value for the X-axis.
  • Default y-scale: Set the default scale value for the Y-axis.
Tip: When using the Text Auto Scale plug-in, Text Box scaling should be set to Off to avoid conflict in scaling operations.
