Drop Shadow
images/download/attachments/27789818/viz_icons_dropshadow.png
Drop Shadow is a shader plug-in that generates 2D shadow of a texture.
images/download/attachments/27789818/plugins_shader_dropshadow_tree_example.png
Note: This plug-in is located in: Built Ins -> Shader -> Texture
Drop Shadow Properties
images/download/attachments/27789818/plugins_shader_dropshadow_editor.png
  • Distance: Set the distance of the shadow.
  • Direction: Set the direction of the shadow in degrees.
  • Threshold: Set the shadow threshold.
  • Soft Shadow: Enable the Soft Distance parameter for applying a soft shadow.
    • Soft Distance: Set the distance of the soft shadow.
  • Color: Set the color of the shadow.
