Text FX Jitter Scale
images/download/attachments/27789481/viz_icons_tfxjitterscale.png
The Text FX Jitter Scale animates a jittering effect on the scale of the character.
Text FX Jitter Scale Properties
images/download/attachments/27789481/plugins_container_textfx_jitterscale_editor.png
  • Anchor Horizontal: Sets the anchor point for the characters on the horizontal plane.
  • Anchor vertical: Sets the anchor point for the characters on the vertical plane.
  • Use Axis: Defines on which axis or axes the characters scale to create the jittering effect.
  • Lock Axis: With this option enabled, all the axes get the same Min, Max and Randomness settings. If you disable randomness, these parameters will be visible for each of the axes and must be set individually.
  • Min: Sets the minimum scaling for the characters.
  • Max: Sets the maximum scaling for the characters.
  • Randomness: Sets the intensity of the jittering movement.
