Tex Component
images/download/attachments/27789524/viz_icons_tex_component.png
The Tex Component plug-in selects which component of a texture is used for the texture mapping process.
Note: This plug-in is a legacy plug-in and the functionality is now incorporated into the Texture Editor.
Tex Component Properties
images/download/attachments/27789524/plugins_container_tex_component_editor.png
  • Use Component:
    • Alpha: Only the alpha of the texture will be used. The RGB color of the texture will be set to a constant color specified by the Constant Color parameter
    • Color: Only the RGB color of the texture will be used. The alpha will be set to a constant value specified by the Constant Alpha parameter
    • Alpha+Color: Both the alpha and the RGB color of the texture will be used (default setting)
  • Constant Color: Set the constant RGB color of the texture when Alpha is se
