Frame Mask
images/download/attachments/27789686/viz_icons_framemask.png
This plug-in adds a framed mask around an object (e.g. image or geometry). In the properties the aspect ratio can also be set.
images/download/attachments/27789686/plugins_shader_framemask_scene_example.png
Note: This plug-in is located in: Built Ins -> Shader -> Effects
Frame Mask Properties
images/download/attachments/27789686/plugins_shader_framemask_editor.png
  • Left, Right, Top and Bottom Edge: Set the tracked borders (see also Tracking).
  • Left, Right, Top and Bottom Gradient: Set the gradient from the edge of the frame to the edge of the object.
  • Aspect Ratio: Set the aspect ratio (16:9, 4:3 or Custom), if required (default is Off).
  • Custom: When Aspect Ratio is set to Custom, use to set a custom aspect ratio (e.g. 1.85:1 or 2.39:1).
  • Tracking: Instead of animating all tracked borders manually, use a Container to track the location of the actual frame mask. Drag a Container to the drop zone (1):
    images/download/attachments/27789686/plugins_shader_framemask_container_track_anno.png
