Control Image
images/download/attachments/27789238/viz_icons_controlimage.png
The Control Image plug-in creates an image control in the control clients. The plug-in must be placed on the container that holds the image/texture. If an image/texture is invalid or Viz Engine for some reason cannot load it, then the current image/texture remains visible.
Control Image Properties
images/download/attachments/27789238/plugins_container_controlimage_editor_r.png
  • Expose Image Position: Allows the user to change the position of the image/texture.
  • Expose Image Scaling: Allows the user to change the scaling of the image/texture.
  • Deny Browsing Upwards- When enabled, it restricts the user from browsing for images/textures in folders other than the selected folder and its sub-folders.
  • Image location Prefix: If the full path to a folder is entered, the image/texture location exposed to the control clients can be a simple string, instead of a full path. This is relevant if connected to a newsroom system. For example if a user wants edit a text and an image/texture on the same tab-field by just entering a text string. This is relevant if a user has a folder containing flag images/textures, and the control client receives “US” from the external system it will load the image/texture with the path: “image location prefix + US”, which then typically would be the “Stars and stripes” (flag of the U.S.A).
  • Input Value: Shows the current value for the plug-in. It is not necessary to set any value here. It is used for debugging purposes.
