DVE Follow
images/download/attachments/27789571/viz_icons_dve_follow.png
DVE Follow connects a video input channel or a clip channel of the containing Scene with the bounding box of a Container. When connected the channel, if set to DVE, will follow the bounding box of the Container. The plug-in does not actively set the channel to DVE.
IMPORTANT! Be aware of the fact that the DVE animation is done on the video board while the animation of the ruling container is done together with all other graphics on the GPU. The output delays of the graphics and the DVE animation are different and this can lead to notable offsets between graphics and DVE (especially notable with fast animations).
DVE Follow Properties
images/download/attachments/27789571/plugins_container_dve_follow_parameters.png
  • Channel Type: Type of channel to manipulate:
    • Video Channel
    • Clip Channel
  • Video/Clip Channel Number: The plug-in supports a maximum of eight video channels and 16 clip channels.
  • Layer: Select the layer which contains the Scene in which the DVE is located
  • Video Width: With of the containers bounding box
  • Video Height: Height of the containers bounding box
  • Alpha: Alpha value of the DVE channel
  • Priority: Priority value of the DVE channel
  • Crop: Left, right, top and bottom crop value of the DVE channel
