Built Ins
In Built Ins there are a standard set of Viz Artist installation plug-ins.
images/download/attachments/27788120/manage_elements_builtins_content_tabs.png
Most plug-ins can be added to Containers, except, for example, Scene plug-ins. Because Viz Artist uses an open interface for the plug-ins, new geometries can either be obtained or created and then installed with Viz Artist. Also, most plug-ins have a properties editor. When a plug-in is applied to a Container in the Scene Tree, a plug-in icon will be added to the target Container.
The Built Ins button on the Main Menu gives access to the various plug-ins:
Content Tabs
The Built Ins are contained under various tabs and in folders.
images/download/attachments/27788120/manage_elements_builtins_content_tabs_anno.png
Click on a Built In tab to open its panel and folder list. Double-click a Built In tab to open its panel and go to the default folder in the folder list. Default folders are:
  • Geometry plug-ins (GP): Default
  • Container plug-ins (CP): Global
  • Shader plug-ins (SH): Default
  • Scene plug-ins (SP): Default
  • Media Assets (MA): Channel
Plug-in Context Menu
A right-click on a plug-in icon to open the plug-in context menu.
Geometry, Container and Shader Menu
images/download/attachments/27788120/manage_elements_plugin_context_menu_1.png
  • Add to Container(s): Add the selected plug-in to a Container(s).
  • Add as Favorite: Add the selected Texture to the Favorites Bar.
  • Delete from Favorites: Delete the selected Texture from the Favorites Bar.
Scene Menu
images/download/attachments/27788120/manage_elements_plugin_context_menu_2.png
  • Add to Scene: Add the selected plug-in to a Scene.
  • Remove from Scene: Remove the selected plug-in from a Scene.
Media Asset Menu
images/download/attachments/27788120/manage_elements_plugin_context_menu_3.png
  • Add <Media Asset> as Texture: Add the selected Media Asset to a Scene (automatically adds a new Container).
  • Add <Media Asset> as DVE: Add the selected source as DVE.
  • Show settings of <Media Asset>: Show the settings of the Media Asset, if it has been added to the scene and the Scene Tree is in Texture or DVE view.
  • Add as Favorite: Add the selected source to the Favorites Bar.
  • Delete from Favorites: Delete the selected source from the Favorites Bar.
For the Background and Foreground media assets, the context menu shows the Favorite options only.
View and Search for plug-ins
All plug-ins can be dragged straight into the Scene Tree (except Scene plug-ins). Double-click a folder tab to go to the Default folder for that plug-in category.
To View plug-ins
  1. Select Built Ins.
  2. Select the appropriate plug-in category, either:
    • From the drop-down menu that shows above the plug-ins view, or
    • Click on of the tabs, or
    • <Ctrl+1>: Geometry plug-ins
    • <Ctrl+2>: Container plug-ins
    • <Ctrl+3>: Shaders
    • <Ctrl+4>: Scene plug-ins
    • <Ctrl+5>: Media Assets
The All folder in the left panel, offers an uncategorized view of all plug-ins. Pressing a letter on the keyboard to jump to a plug-in which starts with that letter.
To Search for a plug-in
You can drag plug-ins from the search results to the desired destination.
  2. Open the plug-in search panel, by opening the Built Ins drop-down menu and selecting Search..., or pressing <Ctrl+F>.
  3. Enter a search string and click on Go (4), or press <Enter>.
    images/download/attachments/27788120/manage_elements_built-inmenu_search_text_anno.png
Add Plug-ins to Containers
images/download/attachments/27788120/manage_elements_plugin_dragdrop_annos.png
Most plug-ins can be dragged to a target Container(s) in the scene tree (1), the Properties Panel (2) or the Scene Editor (3). Each plug-in also has a context menu where a plug-in can also be added to a Scene.
To Add a Geometry plug-in
A Container can only contain one Geometry plug-in at a time. If a new Geometry plug-in is added the fist one will be removed from the Container.
  1. Drag the Geometry plug-in icon to either:
    • A Container or multi selected Containers
    • The scene tree area (creates its own container)
    • The Scene Editor area
    • The Container Editor area
      or
  1. Highlight the target Container(s)
  2. Right-click the plug-in icon and select Add to Container(s) from the plug-in context menu
To Add a Container plug-in
  1. Drag the Container plug-in icon to either:
    • An object in the Scene Editor (only some container plug-ins will do this, when they will the object becomes active when the icon is moved over the object.
      or
To Add a Shader
A Container can only contain one Shader at a time. If a new Shader is added the fist one will be removed from the Container.
  1. Drag the icon to either:
      or
To Add a Scene plug-in
  1. Open the Scene plug-in tab:
    • Click on Scene Settings -> Plug-in
    • Click on the Scene plug-in icon (1). When a scene plug-in has been applied to the scene, this icon will turn to orange images/download/attachments/27788120/manage_elements_sp_icon_2.png .
      images/download/attachments/27788120/manage_elements_sp_icon_anno.png
  2. Drag the Scene plug-in icon to the Scene drop area.
    or
  1. Right-click the Scene plug-in icon to open the plug-in context menu.
  2. Click on Add to Scene...
To Add a Plug-in to Multiple Containers
  1. Highlight the required Containers.
  2. Drag a plug-in icon to a highlighted Container
  3. Release the plug-in icon.
    or
  1. Drag a plug-in icon.
  2. Hold the plug-in icon over a Container.
  3. Continue to hold the left-click and do a right-click to drop the plug-in icon on the Container.
  4. Continue to hold the left-click and repeat for each required Container
To Add a Plug-in to Favorites
  1. Right-click the icon to open the plug-in context menu.
  2. Click Add as favorite...
You can also add plug-ins as favorites from the search panel.
To Open a Plug-in Properties Editor
Click on the Media Asset icon, in the Container or the in the Properties Editor.
