Server Panel
The Server panel shows an overview of all available items in the Graphic Hub database.
images/download/attachments/27787913/tree_knowledge_server_area_anno.png
The Server panel is divided into two sections:
  • Server Tree (1): Shows the logical tree of folders in the Graphic Hub database.
  • Item Panel (2): Shows the items contained in the folder selected in the Server Tree.
    Tip: To resize the two areas, drag the vertical separator.
    The Server panel is enabled when Server, Server/Stage or +Tree/Stage is selected from the Main Menu.
